What size wheel studs
Ron816
Mopar forever
Quincy, MA
What is the front wheel stud size for 68 gts with 10 inch drums Small bolt pattern
45 seconds...
i ordered from rock auto 1900B they where the wrong size too small studs on my hubs are 1/2 diameter
My understanding, A bodies all had 7/16 studs, B-E body had 1/2. If yours are 1/2 then it would seem that someone swapped your hubs, or drilled them out
mystery solved I just checked the other 3 hubs they are 7/16
the other is 1/2 looks like someone changed the hub, thanks for the info
You will need drum as well if it is 1/2 inch
Look on the left side 7/16 studs for a L on each. you might still have left-hand lug studs on the left side.
