jbc426
I have used 3 Precision of New Hampton converters in my rides over the last decade. They were all amazing, not inexpensive, but some of the best bang for the buck you can buy.
I was running a 2004R in my '68 with a 3700 rpm stall and a 3 carbon fiber disc lock-up clutch. I wired the transmission so I could lock or unlock the converter in 4th gear. Unlocking it at 65 mph would add only 350 rpm versus locked up.
As mentioned above, when using heavy throttle the converter would flash to 3700 rpm. Around town, you couldn't tell it from a stock converter.
