1974DartSport
Senior Member
My 74 Dart has three bolts that hold the intake manifold to the exhaust manifold. The long bolt that is by itself takes a 3/8" nut with the washer built into the nut. I have that nut. The other two bolts were removed by the media blaster. He broke them during the cleaning. The two holes on the intake manifold are smooth, 5/16" holes right above the hot box area and the threads screw into the exhaust manifold. Here's my question. Did the factory bolts have threads at both ends of the bolt (like cylinder head studs) and use a nut with washer to hold the top of the intake manifold down?
I went by the local Chrysler dealership and they pulled up a 1987 slant six on the computer. (Computer records only go back to 1984.) Looking at that bolt, it was 5/16" but it had a head on one end and was inserted into the smooth holes on the intake manifold and screwed into the exhaust manifold. (ie. there were not threads at both ends like the cylinder head bolts.) I am trying to keep the engine as it originally looked when I bought it in 1974. Anybody know what Dodge originally used?
