LovetheA's
Well gang once again I need to tap into the great wealth of knowledge at forabodiesonly . To make a long story short a mechanic who obviously knows very little about Darts trying to help me out created a problem. I had to have my voltage regulator replaced because the old one had crapped out. Instead of checking with me first. This *** clown drills two holes in my firewall to remount my voltage regulator. He did this because the original holes holding the old voltage regulator were at one time opened up to accomodate larger bolts not being able to use the correct firewall bolts for the regulator. So what I want to do is plug the new holes. Move the regulator back to the original spot and find some way to use the smaller original bolts for the regulator. I can't helicoil the firewall because it isn't thick enough and I don't want to but the bolts through and anchor them with nuts behind the firewall too difficult. Is there any type of fastener that I could put into the oversided holes that would grab the smaller bolts and lock onto them?
Carl
Carl
