purplescamper
I got this overflow canister yesterday with no instructions. it has two tubes on the bottom and I'm trying to figure out what tube does what any ideas ?
Look at the inside and you should see the two tubes are at different levels.
The shortest one goes to the radiator so it can pull coolant back into the engine.
The taller one is the overflow where pressure gets released, or if the tank fills too far the coolant can drain out.
I made mine out of a shotgun shell thermos and used the bottom of it the same basic way your new tank works so there are no hoses out in plain view.
The 26 inch radiator needs every bit of that volume.
