What's she gunna do?
BadAss71
Let's Go Brandon
Pueblo West
Taking the dart to the track tonight, running nitrous for the first time on her. Last time out to the track it went a 12.30 at 109 with a 1.80 sixty. With the 100 shot I expect to see an 11.6 or so. What do you guys think? I will be spraying off the line by the way.
You'll find out lots of things.....how well you built the engine.....if you have a strong enough rear end/trans/diveshaft/etc, and if you chose the right compound tire.....
i think if you spray off the line you might spin the tires..hurting your time...but try it out, if that dont wont, spray after you take off and get goin...
Did you pull 4 degrees out of the timing? You might want to close the gap on the plugs, 0.025" works with 100 HP of spray. Try to get the bottle up to 85 degrees for full pressure. What kind of tires are you running?
