'74 Dart, 225 /6, A904. Leaks badly at the pan gasket and shift shaft seal and will be replacing soon. As long as I'm going to be in there, I'd like to address a couple of other issues. I am NOT a transmission man so forgive me if I ask some dumb questions. Tried to get Aamco to "service" the transmission, thereby getting the leaky pan gasket replaced, but they refused to do anything unless they rebuilt it due these other issues. They also wanted $1400 just for labor, not counting parts. Anyway, here's my symptoms: When cold and the engine first started, if I put it in gear it just rolls down the hill. Once I let it warm up, it kicks into gear but growls and shudders taking off. If I let it warm up, put it in gear, increase the revs a little until I can feel it pulling, and sit that way for 1-2 minutes, then take off, it functions fine. When warmed up, driving on a level road, or a slight grade, everything shifts fine. Start going up a steep grade at low rpms, in drive, it'll start to slip and whine/growl. Downshift to 2nd and it's fine. Peak the hill and level out, shift to drive and it's fine. When warmed up, going up a steep grade from dead stop, it'll growl/whine almost immediately. Put it in 1st and go up it rapidly and it's fine. Halfway up the hill, shift into 2nd, it'll whine/growl/slip. Slack off the gas pedal, growl/slip stops and it's fine. Shift into drive going up the hill it'll whine/growl/slip till you top the hill. When warmed up, going a good speed, hit a steep hill, stay on the gas and keep the rpms up, it's fine. Only seem to slip/growl/whine in situations involving high load at low rpm. While I've got the pan off, and the valve body dropped to replace the seal, is there any adjustments that should/could/need to be made like tightening bands or something? Is my torque converter the problem? If the tranny's dying, how long do you think I have before it's going to need a rebuild/replace. I drive an 80 mile round trip to work/day on the same road at the same time and the same speed every day. Any and all input or advice is greatly appreciated!
