Whats wrong with this picture?
Yes, maybe it's a local thing, but tang is what we would call it here. Was just saying that I had never heard it referred to a a notch.
Notch in the block or con rod and the matching caps. Tangs on the bearings to locate the bearing in the bore.
I use a fine file to just "deburr" the side opposite the notches to prevent that sharp corner shaving a bit off the back of the bearing. Put the tang in the notch and then push the bearing into place.
Whats wrong with this picture.......A Mopar builder is dirtying his soul by building a Chebby.....and it's now 2023 and what is in the picture has become normal.
You could always make a Tang sandwich like Al Bundy.
