[FOR SALE] Wheel adapter spacer 5x4" to 5x4-3/4" x 1" thick
69FBCuda
Stand back 10' for your viewing pleasure & Safety
Florida
Wheel adapter spacer 5x4" to 5x4-3/4" x 1" thick.
Threads are good, holes are round.
Pulled from the front of a 65 Barracuda.
Appears to be cast and weighs 2.25 lb
Markings are: SEMA APPROVED PART NO 01-02
$30 Shipped.
Paypal accepted-buyer pays fees if any.
Thanks FABO.
Located at zip 32764 FL.
In the diagram from post #8 from pishta, measure as he has shown from outside of the top point to the inside of the bottom point & it will tell you 5 on 4 1/2", or 5 on 4 3/4". That will be the receiving bolt pattern, same thing for the hub pattern & it should measure for 5 on 4" pattern.
middle of stud to back edge of stud 2 away, but it sure looks very close to 4.5. Trans-dapt sells them now but I can't tell if the part is a generic stock photo to see possible 01-02 part number. Buy one, good for a 4.5 BC spare on a BBP rear end equipped early A that still has 5 on 4 fronts, I know they exist........:-)
