Wheel Bearings...
RustyRatRod
Caput villa stultus
Georgia
In refurbishing the SBP Kelsey Hayes disc brakes for Vixen, I am trying to find the part number for the outer (small) front wheel bearings. No one that I can find specifically lists them for "disc brakes". I am just spitballing here.....are they the National A2 bearings? Thank you drive through.
photos are copied from a member for reference
A2 and A6 according to my notes. Except I wrote the inners are A2 and outer are A6.
Hey RRR, for your info, I followed the parts recommendations in that thread to a 'T'. I feel like the 15/16" bore master makes for a pedal that is too soft.
My wagon STOPS with the 4-piston disc's, but in a panic situation I can shove the pedal all the way to the floor and barely lock the front brakes.
I'd like a firmer pedal. I'm going to go to a master with a larger bore soon.
K-H disc's, non-power, stock 9" drums out back FWIW
That's interesting. Thank you.
I like the feel on my 1974 Dart master with the KH front 10" drum rear though some may dis-agree.
