Gabriel Larson
Dose anyone know a part number or name for the hardline that comes of the wheel cylinder on the front drums?
no first time looking at the brakes. very interesting!That's for 10" drum brakes. You shouldn't need those short hard lines. Those were only used on the 9" brakes. The brake hose should go directly into the wheel cylinder. Did you do some sort of conversion? Looks like you have a hodgepodge of parts there.
I just made some lines and got some of those nicop went back and found steel. I wouldn't put that soft stuff on my vehicles. But have you had luck I mean after a few panic stops?You can make your own lines(if need be) with NiCop brake lines. VERY easy to bend.
