Inspector71
My 68 Barracuda has been in storage since 1986. I bought it from a salvage yard in California. It is a 225 slant six, UU1 blue with black interiror, column shift automatic. The drive train is gone and it is almost rust free and needs no sheet metal work anywhere only a paint job and drive train. When I have the money, a 360 engine will go in the car. Obviously the drive shaft and rear will have to be changed. I apologize for asking what has probably been asked many times (and I did a search first) so if you can be patient, I have the following question.
Does this car most likely have the 4" instead of 4.5" bolt pattern?
I am interested in the chrome rallye wheels. Would these take a trim ring as well as the argent colored version?
Year One sells these wheels along with several other vendors. I read on another Mopar forum that Vintique wheels were not good and customer service bad. Year 1 carries these wheels. Is that correct information or are they okay?
Some of the Disc brake conversion kits state a 15" wheel must be used. Are there kits if I want to stay with the 14" wheel instead?
I tried to measure the bolt distance from the outside of the wheel and it was not too accurate. Do I need to take the wheel off and measure from the outside of the designated hole to the the middle of the other specified hole (I have the diagram) or from the edge of the designated stud to the other stud?
Thanks for the help. This car has sat too long but a move from California, children born, two more moves, divorce from one of the queens of the damned, two more moves, remarriage, two more kids...you get the message.
