Need to replace some front wheel studs, still have left hand thread on the left side. Is there any benefit to going from 7/16 to 1/2 inch on the front other than the lug nuts all the way around will then be the same?
I don't think you can switch from 7/16" to 1/2" studs without enlarging the holes in the hub unless you can find the correct knurl diameter in a 1/2" hmmm :scratch:
I used to drive the wheels off my street car with the small front studs.Well at least I thought I did. But I never did.They seem to be strong enough for street.
