gzig5
If the gear tooth profile is different in any way, it won't mesh correctly with a stock cam gear. The width of the gear doesn't affect it's function, only how much load it can carry and maybe whether it will fit. You generally want the widest gear you can fit to reduce the tooth load, but in this application I can't see that wider gear making a difference in anything but an all out motor that needs high rpm endurance.
