More Larry info
Oil Pump Drive
Another concern relates directly to the camshaft you use. If you plan on using a hydraulic roller cam or a mechanical roller cam in your engine, you should have an intermediate shaft, which uses a bronze gear or an aluminum-bronze gear. It is gold in color so it is very easy to determine if you have one. It should be pinned to the shaft. The problem is that these roller cams are made from steel and the production gear wears out very quickly when run against a steel gear. The bronze material solves this metallurgy problem.
Magnum engines, which already have a hydraulic roller cam made from steel, are tricky. Chrysler engineers solved the steel problem by alloying and heat-treating the gear. My problem is that the finished production part looks just like the A-engine production part, which should not be used with roller cams. The Magnum part should work with all rollers, but you might talk to the cam experts (Comp Cams or Crane) to see if they have encountered any issues. If in doubt, use the Magnum shaft for the hydraulic cams and the bronze gear with the bigger cams.
The stock part doesn’t typically break by the gear. However, the gear is only pressed onto the shaft, so in high- performance applications, the gear (black or dark gray) can slip on the shaft. Moreover, the small end of the shaft just above the oil pump hex can fail. For performance engines, the first concern is to get an intermediate shaft that has the gear pinned to the shaft. These are available from Mopar Performance or Milodon; both use a heavy-duty shaft.
If the engine is being built for the street and for durability (high mileage), you might consider the Milodon bronze gear, which claims premium material for better wear resistance.
Mopar Engine Performance Guide: Oiling System - Mopar DiY
