Where can I find these shifter rod clips
moparmat2000
Grand Tetons
Where can I find these rod clips. They are similar to the 4 speed rod clips but are smaller. I have 4 speed rod clips and they are too big for my automatic trans shifter rods.
Thanks
Matt
Passion performance or Brewers performance they both deal in manual trans parts
As noted.. he needs them for an automatic and it's linkages. I used cotter pins last week on mine...
I have snap clips for the other 3 but the rods are just sloppy with them. I have a bag full of 4 speed rod clips, but they are too big
If it says manual trans, they are going to be too big. There is a spot on the kickdown bellcrank that gets one of the larger clips I believe. These are quite a bit smaller.
Thanks!!
I wonder where I can get the clips seperately, or even wave washers would work with the clips I have.
Thanks
Matt
Matt, I also had some sloppy linkage rods and found the nylon washers took up the slop.
You can either use a thin one, on top of the metal washer (which I think will last longer due to the metal washer being a backing plate to the nylon washer), or replace the metal washer with a thick nylon washer.
Just a suggestion, as it worked for me.
