Where do the hoses go...
'74 Sport
Troy, TX
...on a 4-bbl Holley 4160 (LIST 3310-4) 750 cfm vacuum secondary?
Namely, the PCV hose and all necessary vacuum lines. I'm guessing the PCV goes to the larger nipple on the back of the carb.
Thanks,
Jerry
that is correct pcv goes to large nipple on the back...
vacuum advance goes to ported nipple on primary metering block on passenger side of carb...
there is usually another vacuum nibble that is at an angel under the front fuel bowl...it is full time vacuum..
