where is turn singal flasher ? 69 Dart
Think this has been covered, more than once on here. Under the dash between the ashtray & the glove box is where it should be.
If you have an under dash a/c unit it can be nearly impossible to find it with out removing either the a/c unit or the glove box liner
If it works, turn it on and you will hear it clicking. I found mine in my 69 Dart long ago when the wires to it fried. We were driving on a washboard gravel road in NM, which must have shook it into a bad state. I buy only the best turn signal switches since then. I think that one was the original.
