Where to buy Mopar performance 383 electronic ignition Kit
73dart360
fort lauderdale
I am looking for a Mopar electronic ignition kit For my 383 any help would be appreciated ,I see alot of aftermarket -do they still sell the mopar kit
4 seconds flat
HEI
MSD
Hard pressed to tell anyone to run anything else. MSD tops my list. Always had issues with the MPP stuff.
No need for a "kit" per-se. Figure out what ignition system you want to use, buy the parts, and install. You can get away with a factory electronic distributor, HEI module, mount and e-core coil for instance. Or a factory electronic distributor, mopar ECU box, ballast resistor and harness. Or even use a factory points distributor and pertronix kit. These are just three of MANY choices.
