Where to put '68 Dart rear window trim clips??
Max Wedgie
Yonder
New ADM quarters were installed on the Dart a few years ago, and it's finally painted and being put back together. Some of the original rear glass trim clip mounting holes have been filled in with epoxy and/or heavy primer. Need to know the approximate locations of the original trim clip holes.
Someone had posted this chart on a previous thread but I cannot find anything for rear glass with a Google search. Anyone have something similar to this that pertains to a Dart?
Thanks for any info!!
I have the rear glass trim off my 68 I'll take a couple pics and measure spacing for you later today, Ron
The measurements are center to center, the 3 clips on both sides are spaced out evenly coming off the corners about2 inches
Would they have to be 'exact" as long as the trim is properly clipped in it should work even if you are a little off.
I agree they don't have to be exact only area to be aware of are the corners don't put the clips too close to the corners move them out a bit
Also, if there are two pieces across the top with a seam in the middle, don't put a clip right in the middle. Don't know how Darts are, but ran across that on a Barracuda fastback.
Thanks everyone ..they don't have to be exact of course, but don't what the bottom corners of the trim sticking up too high if I put the clips too far away.
If you study a variety of reveal moulding clip patterns, you'll find there is no rocket science to it. First are the clips a couple inches from any corner, curve, or join of 2 pieces. The remainder is equally spaced between those.
