reddishdsb
- Joined
- Jul 15, 2006
- Messages
- 244
- Reaction score
- 14
73 318 stroker 6 bolt crank to 904 trans, will the b & m 10230 work?
There are two bolt patterns for the flex plate to the crank. Offset and symmetrical... See what your crank has and match that..
I believe you're confusing the flexplate-to-crank bolt pattern to the 2 different balancer/damper bolt patterns for pulleys. Mopar V-8 cranks all have the same 6 bolt crank-to-flexplate pattern out back. Some high dollar aftermarket units & Hemis have an 8 bolt pattern. But you are correct about the different converter patterns and bolt sizes.
The engine builder will know or determine what it needs. It all depends whether it was or will be internally or externally balanced.
Have to watch the OD of flexplate occasionally for interference with the starter.
Check my link to the mancini flex plates. They offer them in symmetrical and offset, with 10" or 11" torque converter mounting...
I just ran into this issue. I used the B&M 10230 flexplate and had to get a different starter to clear the larger diameter. Other than that, everything bolted up fine.
I'm sure most are happy users, but I wouldn't trust a stock flexplate for performance use. The ones I've seen break over the years, even the solid-eared ones, have been at the dragstrip. But this includes 13 second cars.Heck may just stick with the stock one.
