LovetheA's
This is one for the guru's. Could someone please explain this to me. I know that in 1967 the hi-po head that was common on the 383 or 440 was the 915. I also have been told that because of it's closed chamber design it will easily raise the compression resulting in substantial power gains. What I need schooling on is a comparision. Assuming you have two identical motors say a 383 or 440 from carb to pan expect for the heads. One motor has a set of 915's on it and the other a set of 906's. If the compression ratio on both motors are identical at about 10 to 1. Which motor makes more power, torque and flows better and if so why? Was always curious about this?
Carl
Carl
