Which intake manifold gasket would you use???
I personally had better luck,with the Mr Gasket product, out of those two. Both work well,just preference on my part. One thing, you didn't mention: metallurgy. My references are to,aluminum intake & cast iron heads.
Yes, aluminum intake and iron heads.
stock exhaust manifold with heat riser might burn through gasket . is it a street car ? and does your intake have a heated crossover?
It does have the heat crossover. I am using headers. I didn't think about the heat crossover. I need that for the choke.
I ran the edelbrock gasket with iron heads and it did it's job. I had a small leak at the back but that's from not enough rtv. I'm going to Eddie heads now with my performer rpm. I'm trying to find the best gasket now too.
I have used both of those gaskets you listed, and they both work fine. Just remember to toss the end seals and lay down a bead of silicon instead.
Definitely. I won't even use those on a stock iron intake.
I had to rethink the gaskets. The gaskets I linked don't have the opening for the heat crossover. I am looking at the edelbrock gaskets now. They have the extra sealant around the passages like the others and they also have the center hole for the heat crossover.
