68'barracuda
a 1973 360 or
a 1968 318
a 1968 318
a 1973 360 or
a 1968 318
If I had to guess, eliminating all other variables, the '73 360 would be much better since it had similar compression, similar heads, more cubes.
I'll agree - but from driving both in my car they stroke difference makes it have more torque. So the 360 wins - but because of the longer stroke IMO
a 1973 360 or
a 1968 318
Are we talking a......
1973 Heavy Azz big bumpered,parrot nose Dart Sport
VS
1968 light weight 318 Dart
Might have to take the 318 Dart. I think it will be closer than you think.
Or are we talking a 318 vs 360 on the dyno ?
Ouch!
Oopsie.....Sorry !
Not much to go on there? Both stock and 2 bbl? Is one of them filled with sludge? A good built 318, bump up the compression, some mild head work, and a cam with a 4bbl vs. a bone stock 360 2bbl.........lots of variables that can not be answered without info.
a 1973 360 or
a 1968 318
Mostly true, however that saying is like 30-years out of date. The replacement is called "volumetric efficiency".there is no replacement for displacement.
compression ratio is your second best friend.
That saying is never out of date. Never will. You can have volumetric efficiency in both engines & the 360 would be that much better. Every 318 lover out there likes to put up an argument for the 318 that with a cam & some head work & a good intake & headers blah blah blah you can make more power than the stock 360. Well it isn't gonna cost you any more to do all that to a 360 & you'll definitely make more power doing it! They act like the only small block parts out there only fit 318 & 340s.Mostly true, however that saying is like 30-years out of date. The replacement is called "volumetric efficiency".
exactlythat saying is never out of date. Never will. You can have volumetric efficiency in both engines & the 360 would be that much better. Every 318 lover out there likes to put up an argument for the 318 that with a cam & some head work & a good intake & headers blah blah blah you can make more power than the stock 360. well it isn't gonna cost you any more to do all that to a 360 & you'll definitely make more power doing it! They act like the only small block parts out there only fit 318 & 340s.
360 all the way!!
it is going to be put in a 68 barracuda........
just checked the 360 it might be locked up wouldn't turn over
