Which Sway Bar?
73dart_swinger
What brand of sway bar do ya'll suggest for a 73 dart without factory sway bar control arms?
I am using a 73 Dart spool mount k-member in the Barracuda and purchased an ADDCO sway bar for the 73+ k-member. It came with nice heavy mounts, poly bushings and angle iron brackets that bolt (I bolted and then welded after I had everything adjusted) to the control arms.
The bar is 1 1/8" and made a dramatic improvement in the handling of the car.
