Which U Joint do I have?
Save your money and don't bother with those... If the driveshaft happens to go to an extreme angle, you get a nasty mess. DAMHIK!
Run the straps or a set of U bolts if you can.
Oh?
I figured they would be beneficial since my U Joints already exploded once leaving my driveshaft smashing my floor pans and the concrete over and over.
What are these straps or U bolts you speak of for the U joint?
If you are breaking U joints, there is a problem most likely other than the straps. Angle, neutral drops.
I run the stock style straps all the time. I don't really recall a 7260 yoke with U bolts. 7290 may possibly have a u bolt style.
Measure the inside spread between the cups of the yoke, 2 1/8 = 7260, 2 5/8 = 7290.
hardware here:
http://chucker54.stores.yahoo.net/mounhar.html
