While rebuilding the front suspension on our 72 Dart the center link got turned around and I am not sure which end goes to the pitman arm. The holes are the same size but one is offset a little.
Very first thing you need to determine is whether you have late or early steering, that is 73/ later or 72/ early, and it could have either, that is, someone could have converted. My car will be late after it's painted. You determine this by looking at the stud on the pitman arm. Does the stud / nut on the pitman point up or down?
