Map63Vette
So I just finished swapping a 5.7 into my Dart and I kept the old 833 that was sitting behind the old 318. I shortened the input shaft for the register style pilot bushing by around 5/8 of an inch as suggested and measured by me, but now when I drive around I get a while in all gears, not just the low ones. The car used to have a bit of a whine in first, which I figured was normal because of the low gearing, but now it whines even in third and maybe fourth. Any ideas what might be causing it? I drained all the fluid when I pulled the transmission for the swap and filled it back up once I got everything bolted in. Otherwise I can't think of anything else that may have happened to it between taking it out and putting it back in.
