straightlinespeed
Sometimes I pretend to be normal
Ok, so once again Im trying to narrow down issues with my car.
Pulled my plugs to look at them and they are white in color on the electrod. If Im right that means running lean.
I have a LA 360 with magnum heads, xe268 cam, street avenger 670 carb stock jets. Im not sure if you need any other info but what do I do to get this to clear up and burn the correct color? Also will a lean mixture cause it to run hot?
