Perma-Cool fan through a relay,200 watt amp,Msd digital and Holley HP125 electric fuel pump w/relay through the stock alternator.The amperage on the alternators can vary alot from one to another,i had the parts store check the amperage when i bought it to get the highest one they had.The same part #
can vary up to 15 amps from what we found.If buying the fan new(Jegs,Summit)find the highest cfm,lowest amp draw,this makes a big difference as i was running a Tornando type before the one i have and pulled 2 and a half times the amperage with less cfm.
