What determines the difference/similarity between fuses AGA, AGC, AGU, AGW, AGX, SFE and which are the correct ones for a 1972 Mopar (5 and 20 amp)? Tnank you.
The AG stands for auto glass. Example AGC (auto glass cartridge) which is a fast acting fuse.
SFE (standard fuse element)
AGX carries 100% of the load and opens at 200% in 5 seconds
I suppose this is as good a place as any to start reading... Identification of fuses its all about identifying the physical makeup. More than volts and amps to them.
If you find where 'A' stands for auto, that's new to me.
