homecloned
Can't re Member
Does any body want to share their recipes?
I am going to stick with dry rubs and I am trying to get close to a brand called Uncle Mikes from up in Amish country. It is the best I have ever had.
Here's what I have so far:
salt
paprika
onion powder
garlic powder
black pepper
cheyenne pepper powder
I am still working the mix of each.
Meat is whatever I can get for under $2.50 a lb. Preferably cut into steaks.
Put meat in freezer to slightly harden but not so hard you can't cut.
Cut steaks into 1/8" thick strips.
Mix/rub the rub in thoroughly.
Refridgerate for 24+ hours.
I do mine mostly on the dehydrator but have also done it on the grill.
Join in, even if its of a good brand you know of.
Here's my favorite, Uncle Mikes.
This 2 1/2 lb bag run's @$40
And this is mine. Meat was $2.29 lb, you lose some weight when but not that much. It all depends on how dry you like it. The dryer it is the longer it will keep. I like to leave the little pieces of fat on there. There like candy when warm. =P~
salt
paprika
onion powder
garlic powder
black pepper
