stroked340
Looking to buy a set of aluminum heads for the 360 i got sitting here ,while the 340 is still in the works,who got the best deals on DONE heads price/quality..
Where you bought your other set.Looking to buy a set of aluminum heads for the 360 i got sitting here ,while the 340 is still in the works,who got the best deals on DONE heads price/quality..
If your builder machinist guys is so hot **** like you say, then thats who you should be sourcing your heads through.Looking to buy a set of aluminum heads for the 360 i got sitting here ,while the 340 is still in the works,who got the best deals on DONE heads price/quality..
I can vouch for Mike at MRL, great product but there are a few others on here with good reputations too.
If you buy out of the box assembled heads (like Edelbrock) that are mass produced have them check out by a reputable shop.
Is there something a shop can do with out-of-the-box assembled heads that can't be done at home?
Hone guides. Machine the seats. Face valves. Machine the surface (yes, heads come out of the box that aren't flat). Correct stem heights.
Correction is there anything you can't check at home. And no s*** Sherlock on the other stuff.
Do you have a dial bore gauge at home to measure guides? All of the other stuff I mentioned can be done at home if you have the tools.
Oh brother my eyeballs are a dial gauge!
There's a lot of eyeballing going on these days lol.
BTW...I've seen a head with every intake valve bent and they didn't leak. So you can get a valve sealed and still not have a good valve job.
Dwayne Porter, South Burlington VT (Porter racing heads), is in your neighborhood so to speak. He'd certainly steer you in the right direction.
What's the plan Stan?!?!Edelbrocks it is![]()
Sure would like to hear an update on that thread................Bloomer Performance.
Last I heard, Bret Miller had said he wanted to try some different valve jobs. They know someone ready, willing and able to test them out once they make a change.Sure would like to hear an update on that thread................
^^ This ^^
^^NO THIS!!^^I have a set off a 318 I'll send you.
