who's got a kick arse 340 build?
Daz570
Thread Inturpreter
Australia
in the near future I'm going to throw together a 340 for my ap6 ute, (one of these but rougher at the moment)
would like to keep the 340's standard stroke (as they're pretty cool as is around these parts, and use the j heads i have here, nothing over the top, but would like something that will REV,
am thinking a 3.23 diff and 4 speed, car will weigh in at under 1200kg
anybody have any good combinations they'd like to throw up?
Thanks,
Dan.
Knighty. That is very cool looking. Like a barracuda pickup. Anyways I have a standard stroke 340 in my 65 cuda that is capable of high 12 sec. quarter times with traction. I have ported x heads, lunati voodoo cam, rhoads lifters(really help with bottom end power), edelbrock RPM airgap intake & 800 cfm eddy eps carb. Running 3.55 gears with 2800 stall.
Oldschoolcuda
This the motor that I'm running in my 68 valiant. Don at FBO helped me pick the parts out.
Callies 3.79 crank
CompStar 2.100 x 6.125 rods
Diamond Custom Pistons 9.3 to 1
Joe Mondello Cryogenically Frozen Alecular bearings
Racer Brown flat Tappet Cam ST-21( Duration @50 254 554/520) and lifters
Racer Brown Magnum Rocker Arms
Cometic Gaskets
Complete New Magnum/LA heads Stage 3
EV-8 5/16 stem stainless valves
Hardened Exhaust seats
Pro Comp 3 angle valve job
Springs
Retainer
Machined 10* locks
650 mighty demon
air gap
All the motor I need!!!
My 340 has a mild stroke 3.58 crank(372)Scat steel crank
X heads p&p
beehive valve springs
Comp cam XE284H degreed 110
KB107 pistons
bronze guides
ARP main studs
RPM air-gap,Holley 750 v.s MSD dizzy and 6AL box.
Motor was dynoed at 452hp at 5700rpm this is infront of 4 speed with centerforce dual friction clutch,lakewood bell,8 3/4s.g 4.10,s strange bbp axels.It,s got plenty of power for a 372!
