There`s a ton of threads here that focus on the widest tire that will fit in the rear with stock wheelwells but hardly anything about the front. What is the widest tire you guys are running in the front? Rim size? Backspacing? I`m trying to emulate an F/60-15 on the front of my 68 Barracuda which seems to come out somewhere in the 235/60-15 range. Any input would be appreciated.
I have a bazillion different tires and rims on the front of my 68 Barracuda over the years. My car has the large bolt pattern 73-76 disc brake conversion.
Just remember alignment settings, past owners' collision damage, factory variation all play into the sceme of thing when you are pushing the limit of tire size. The first place where you need to look is the front lower fender lip edge.
225/60/15 with 15x7 4.25 backspace in the front is about the biggest. Must run absolutely no less than 4.25" backspace. 4.5 would be better and that is max with a 15" rim. There's a member here Mulinex (sp?) that ran that same setup and it rubbed backing out a driveway and bent a fender.
The alignment's caster setting factors into this too. The more postive caster you run, the front tire move backwards away from the front lower fender lip edge. I run Moog offset 7103 bushings with 4.5 degrees of postive caster. If you run adjustable front strut rod bushing and you shorten them to get your caster, you will move closer to the front lower fender lip edge.
So, my 4.5 degrees of postive caster is helping me with clearance. Also have have poly front strut rod bushings that compress less when backing out of a driveway. And I have 1" torsion bar that don't allow a ton of travel.
The good thing about the 225/60/15 tire size is they there is a ton of choices for tires. And best off, there are some good handling tires in there too. The 235/60/15 are pretty much muscle car type radial T/A's, Cooper, Eagle ST. You can buy a better 225/60/15 tire that will out grip a 235/60/15.
Other setups I've run in the front since 1993...
245/50/15 with 15x8 4.5 backspace very close
245/50/15 with 15x7 4.25 backspace close
225/50/15 with 15x7 4.25 backspace
225/50/15 with 15x7 3.75 backspace rubbed slightly
245/50/15 with 15x9 4.125 backspace HIT with unmodified front fenders. So I folded back the bottom front and rolled the upper lip.
Here's a picture of the car with 225/60/15 and 15x7 4.25 backspacing cop rims. 15x7 rallyes are identical dimensions. Sorry it's small.
