moturbopar
ok im having a weird problem with the brakes on my 69 barracuda. First off it has stock small bolt pattern discs in the front, and stock drums in the back. Has manual brakes. Anyways the problems are the fallowing. Sometimes the pedal feels fine, not spongy or anything, while holding the pedal down sometime it will slowly go down, like it leaking fluid someplace, but everything is dry. Ssometimes when you hit the brakes the pedal will travel 1/2 to 3/4 of the way down befor the brakes work. still not spongy. If i lift the pedal and hit it again the pedal feels fine. The other problem im having is the rear drums stick some times when I come to a stop. a little light throttle and it breaks free from the stuck drums. Could I have a faulty master cylinder? proportioning valve messing up?
