1973dusterkid
Watch This
Ok so I am thinking about pulling the heads and doing a vale job and seals in my 318 on my truck I have a old 4bbr intake would switching from a 2bbr to a 4bbr with a 500cfm carb really make any difference.
summit has cheap 3in headers I can reduce to 2 1/4 or 2 1/2
If it's a street driver, I would recommend a good set of stock exhaust manifolds (like the 68-70 240 manifolds).
Or use headers that do not hang below the k-frame as they will eventually get crushed and not flow worth a dam...
I used to run headers on the street, but went back to stock manifolds.
Less starter and installation issues also. Sometimes headers are difficult to work around, or have too much heat and burn up starters.
