WILL THESE WORK
jonnyrose
canada
will these work on a 360 in an 1968 dart
Passenger side one should. It appears to be a 273/318 manifold but will still fit. The divers side looks like an e-body manifold; others on here would know better if it would fit depending on if your car has power steering or not.
picked up a manifold like this today from the wreckers it slides right on without taking off the plug wires,i have lots of clearence to the torsion bar,so i think a s bent pipe will work,just want to satrt it up and do burn outs,date code is 2-17-77 part# T 3870387-S
The 273 / 318 manifolds have a lot smaller ports that the 340 / 360. They are pretty dirt cheap for the a body varieties. The 68-70 340 are the best but they are very expensive. I think they are repoping them now. About $500-700.
The 72 -76 340 / 360 manifolds are cheaper and easier to find. They have the larger ports, but are not as good as the earlier models. Probably the best value for the money. I paid $200 for a set. These need to be a body manifolds, I believe. Not sure if e body will fit.
I think about anything works on the passenger side, the drivers side is the picky one.
I have a set in my dart, and for my barracuda, i think i should compare port size,dart had a 360 in it,manifolds went in with the engine.
