Will this brake system
rbkt65
jerseyville, illinois.
work fine or if not, what needs changed? 1971 dart, manual from disc brakes from 75 aspen, master cylinder from 84 dodge truck(no power assist), m/cyl is 1.125 dia, rear w/cyl could be 15/16, 7/8 or 13/16. Have dr diff prop valve, car will have 360 magnum and dana 60 rear end. Anything out of props here?
should be fine and dandy, albeit stiff pedaled!
you *might* have to resize your wheel cyls depending on what you start with, but the adjustable prop valve may help in that department.
