I ordered a brake booster through Advance Auto to go with my Wilwood tandem master cylinder setup. I'm having trouble following the installation instructions. I've seen it stated in a few places to make sure the depth correction plug is in the master cylinder if it's being hooked up to a booster. The problem is, when I do that there's no way the master cylinder will go on the booster because the push rod is too long. It's an adjustable push rod and even when it's backed all the way down and the pushed to the back of the booster I can't get the master cylinder to sit flush. Any ideas? Should I ditch the plug and adjust the push rod? Am I doing something wrong here?
Plugged
As far down as I can make the push rod go
Amount of adjustment in the push rod
Plugged
