If you use studs (I do on all my strokers) then all you have to do is use the ARP studs for the tray, egg the holes in it, and carefully position it to clear the rods. I also open the factory slots by about 50%. They will fit using a factory pan and gasket. The other approach is the Milodon tray with the ARP studs. I don't think anything will work with the factory bolts easilly. You'd need to modify it a bunch.
