window channel install
solid340
Ontario,Canada
Has anyone installed the drivers side window channel "plastic clips" on the window. The kit I purchased does not have any holes in the plastic pieces to mount to the window. Do I put the plastic on to the window until it bottoms. Hope it makes sense. The piece I am talking about is the WS0026 in the picture.
I would slide it flush end to end and pierce it using the holes in the window as a guide.
I'm going to do mine next week and will post pics.
AlV
If A-body - The run channel sits flush with top of glass. Puncture using the glass holes as guide, as said, and install plastic guides, then slide into vent frame. Drop into door as a complete assembly. B-bodies I have done removing door glass only.
