Window corner patch panel
swest
Ottawa
Does anybody know if the window corner patch panel from b body fit a body.
Z
if its for the windshield bottom section. i have pieces from a dart here i will send,thanks,mike.
Yes it is for both botoms window corners, are they rust free and how much. any pics, cheers!
yes they are rust free. the price depends on how much of it you need. i will sell this stuff cheap.let me know how much you need.thanks,mike.
I need both sides of the rear lower window corners. Cut both cut like the picture attached withe the red line showing the cut. Not sure if you have that too but i need the lower passeger side front window corner as wel cut to replace the whole steel part in picture below. enough so i dont have to weld in the edges. As much of the corners as possible woudl be great.
let me know how much shipped to ottawa ontario canada k4a4b9, thanks Steven
