Window fell off track
1971Demon340
Mastodon Demon
Pittsburgh, PA
My passenger window fell off its track and I can not figure out how to gain access to the interior of the door. I have a 1971 Demon ( my alias ) and there is a black sill on top and then the door panel below the sill. Can someone explain if I need to remove the sill and the panel and how to do it so that I can fix the window? Thanks for any and all help,
D340
remove the inside door pull (2 Screws), remove the window crank, remove the door latch. Now you can CAREFULLY pry the panel off the door starting at the bottom corner (use a wide putty knife)
The panel snaps in on three sides and is held in place by a channel at the top. Once you have all the snaps out from the door you should be able to pull the bottom out and down.
Do what you need to do and reverse the operation to reinstall.
