Where is the best place to get the bottom window seals for a 66? When it rains my door cards and carpet gets wet. Any other seals that could cause that issue?
Ok just so you know, The 'cat whiskers" will not keep out water. If your door card is getting wet, it is because the plastic sheeting behind it is missing or defective. While you have door apart, make sure the drain holes are clear of debris.
