Ended up pulling the cracked windshield from the dart today since it was finally nice out again. I think either the windshield itself was/is leaking and/or the wiper pivots.
Any suggestions on where to get a new gasket and glass? So far nobody local has anything and if I remember correctly from reading here 4 doors have taller windshields then 2 doors and such. I'm gonna call around to some more shops tomorrow but I'm not very hopeful that I can find it new and local.
Now for the fun part. How bad is it that I yanked a shaft out with the driver side wiper? Both arms were/are seized to the shafts and even with the release it seems gentle persuasion didn't work with the shaft that came out being bent I assume breaking some clip inside and snapping the passenger arm off at the shaft.
Thoughts on how to fix/replace this? Pretty sure the pivot seals are roasted anyway.
With some luck I'm going to pull the dash out tomorrow and see what I can get at from the other side. I'll try and get some more pictures the parts and such.
Thanks
Thanks
