Hello,
I recently Removed the Windshield and Back Glass out of my dart Project to Do Rust Repair on the Pinch welds and Replace the Headliner.
The question I have is How To Properly Install the Front window and Back Glass in again.
I have New Front and Rear Seals, as well as a new windshield.
The Back Glass will be reused as it is in Good condition and came out with out breaking
Both Windows are the Gasket Type and the Front has a Lock strip which i can install - no problem.
What is the best procedure for the glass / gasket reinstall?
Also Do I need to use any sealer with the gasket?
It seemed that the factory used sealer on the Inside of the gasket where it retained the window, but not where it attached to the pinch weld.
Thanks for any help sages!
Greg
Greg
