boosted
Life Needs Air
On my 67 Fastback barracuda. Passenger door frame fits the roof trim perfectly with an even gap. Driver side is hitting at the bend at the top to the trim pc. I found a nut with a slotted screw in the frame of the door at the front. Question is does this adjust that frame top in and out or what does? I need to get the new seal on so I can move forward but that will not work as it is now... I have the pin in the bottom to hold the frame and the bolt in in the door frame.. Just need to adjust the top back some...
