Nite Moves
My 67 Dart when i got it had a reconditioned 3 speed motor.Unfortunately i dont have the harness nor switch. I got the 2 speed wiper motor working but when i went to install the wiper trans i got a surprise.........It wont work. My question is, The 3speed crank works but it wont go one the 2 speed motor. Smaller bolt. The pin on the 2 speed is to short,3speed is like 5/8 long.Can you get a crank arm with a longer pin for a 2 speed? should i try and pound out the pin on the 3speed and tack it? I dont want to wreck the working 3 speed i have is all. Any help ideas is greatly appreciated. Thanks.......The pic shows the 3 spped wiper motor and then one with the 2 speed crank on it.The rectangular hole is different size on both.
