Wiper motor questions
Electrical and Ignition
  1. Cool Hand
    Cool Hand Well-Known Member
    196
    147
    May 13, 2020
    Middleton Wisconsin
    Local Time:
    10:50 AM
    can I use a 2 speed wiper motor instead of a 3 speed on a 1974 duster,and will I need a new pig tail and switch if it bolts up. Or what are some other options to have working wipers on my project. Obviously not doing a restore more of a resto mod. Just want to have working wipers, and a decent looking motor where I have to look at it in the engine bay. Any suggestions or help would be greatly appreciated. 20210109_182033.jpg
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    57,194
    22838
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    10:50 AM
    The switch, wiper motor, and wiring harness must be changed to convert over....
    • Agree Agree x 1
    • 70dart340
      70dart340 Well-Known Member
      325
      80
      Aug 10, 2007
      Lynnwood, Wa
      Local Time:
      8:50 AM
      Mymopar.com has the schematics for both set ups. I have to agree with krazeykuda.
    • Cool Hand
      196
      147
      May 13, 2020
      Middleton Wisconsin
      Local Time:
      10:50 AM
      Decided to rebuild my three speed wiper motor today looks pretty good. Gonna test it tomorrow. Does any one know what wires to connect to 12 volt power to test it? Wanna check speeds and all before I install it incase I missed something when putting it back together.
    • Cool Hand
      196
      147
      May 13, 2020
      Middleton Wisconsin
      Local Time:
      10:50 AM
      20210114_133634.jpg 20210114_134340.jpg 20210114_144117.jpg 20210114_144121.jpg 20210114_163433.jpg
      • Like Like x 1
      • dadsbee
        dadsbee FABO Gold Member FABO Gold Member
        387
        859
        Nov 25, 2020
        Penetang, Ontario
        Local Time:
        11:50 AM
        Bench testing procedure.
        Test #1(Hi speed)
        Connect jumper wire from motor case to battery ground.
        Connect second jumper wire from battery positive to BROWN lead.
        Motor should run hi speed continuously.
        Test #2 (Lo speed)
        Connect jumper wire from GREEN wire to battery ground.
        Join BROWN and RED wires together and connect a jumper wire from battery positive to them.
        Motor should run at slower speed.
        Test #3 (Park)
        Connect jumper lead from GREEN to BROWN wire.
        Connect jumper wire from red wire to ground.
        Connect jumper wire from Blue wire to battery positive.
        Motor should reverse and park.
        (Depending on where the motor had stopped the park feature may have a full rotation or very short rotation
        • Agree Agree x 1
        • Cool Hand
          196
          147
          May 13, 2020
          Middleton Wisconsin
          Local Time:
          10:50 AM
          Thank you will report findings tomorrow. Appreciate it
        • bbab3
          bbab3 Well-Known Member
          175
          64
          Feb 4, 2007
          Local Time:
          8:50 AM
          One thing to check while doing your testing is that it returns to the park position. I disassembled mine when I converted it from B-body to A-body and it would park the wiper arms in the upright position. After taking it apart more than once some how I got it to park the wipers horizontally.
        • dadsbee
          387
          859
          Nov 25, 2020
          Penetang, Ontario
          Local Time:
          11:50 AM
          The cover plates positioning dictates where it stops, as it holds the switch that opens.
        • Cool Hand
          196
          147
          May 13, 2020
          Middleton Wisconsin
          Local Time:
          10:50 AM
          Good to know thankyou
        • harrisonm
          harrisonm Well-Known Member
          2,942
          2925
          Jan 16, 2005
          Topeka, KS
          Local Time:
          4:50 PM
          I have a 2 speed wiper motor and linkage from a 69 Barracuda parts car that I was thinking about cleaning up and selling, but I'd like to test it. Would you know that bench testing sequence? I assume this one was for the 3 speed wiper.
          Thanks.
        • dadsbee
          387
          859
          Nov 25, 2020
          Penetang, Ontario
          Local Time:
          11:50 AM
          That page on Kim's website is still available.. Bench Test Mopar 2 Speed Wiper Motors- Concealed and Nonconcealed
          • Thanks! Thanks! x 1
          • plumkrazee70
            plumkrazee70 Well-Known Member
            2,723
            779
            May 5, 2013
            Medford, Oregon
            Local Time:
            10:50 AM
            Can you elaborate on this?
          • dadsbee
            387
            859
            Nov 25, 2020
            Penetang, Ontario
            Local Time:
            11:50 AM
            The cover plate can be positioned in I believe three different orientations. I'd have to go grab one to look, but they used the same assemblies for A/B/E bodies and parking requires the cover plate to be located specific to each model line. The stop switch is on the cover, so clocking it correctly makes it stop in the right place.
            • Like Like x 3
            • Cool Hand
              196
              147
              May 13, 2020
              Middleton Wisconsin
              Local Time:
              10:50 AM
              • Like Like x 2
              • cudamark
                cudamark FABO Gold Member FABO Gold Member
                7,663
                730
                Mar 14, 2009
                San Diego
                Local Time:
                8:50 AM
                And make sure your fingers are out of the way if you still have the drive link still attached!
                • Like Like x 1
                • Agree Agree x 1
                • bbab3
                  175
                  64
                  Feb 4, 2007
                  Local Time:
                  8:50 AM
                  dadsbee, All of this wiper info would make a great "how to article"
                • dadsbee
                  387
                  859
                  Nov 25, 2020
                  Penetang, Ontario
                  Local Time:
                  11:50 AM
                  I'm just stealing it from my stolen files.. LOL from stuff I've used over the past 5 or 6 years. All at the touch of Google. "3 speed wiper motor testing"...
                • harrisonm
                  2,942
                  2925
                  Jan 16, 2005
                  Topeka, KS
                  Local Time:
                  4:50 PM
                  Thanks. I went to that link, but it raised a question. Do you know the difference the difference between a concealed and non-concealed 2 speed wiper? The link appeared to assume I knew.
                  Thanks.
                • Cool Hand
                  196
                  147
                  May 13, 2020
                  Middleton Wisconsin
                  Local Time:
                  10:50 AM
                  Harrisonm could you start your own thread so I don't get notified everything someone answers your questions in my thread
                • Cool Hand
                  196
                  147
                  May 13, 2020
                  Middleton Wisconsin
                  Local Time:
                  10:50 AM
                  Everything I mean
                • Cool Hand
                  196
                  147
                  May 13, 2020
                  Middleton Wisconsin
                  Local Time:
                  10:50 AM
                  darn auto correct,I'm trying to say every time
